[Gdal-dev] help on ogr2ogr to assign Spatial reference system
Mateusz Loskot mateusz at loskot.net
Mon Jun 11 09:42:03 EDT 2007
Nimalika wrote:
> Can anybody suggest from where to get valid datum names ? I tried
> with D_Kandawala, kadawala both but they are not correct.
You can list projections, ellipsoids and datums built-in PROJ.4 (also
used by GDAL), using proj command. Check the first Q in the FAQ:
http://proj.maptools.org/faq.html
Cheers
Mateusz Loskot
http://mateusz.loskot.net
