[Gdal-dev] Does GeoTIFF support LocalCS?
Ray Gardener rayg at daylongraphics.com
Sun Jun 24 13:32:51 EDT 2007
Has anyone been able to use local CS with GeoTIFF? The best I can get
GDAL to do is write an associated .tfw file out okay, but when reading
back in, GetProjectionRef() in 1.4.1 returns
   GEOGCS["unnamed", DATUM["unknown",
    SPHEROID["unretrievable... UNITS["degrees"...
Since the units (in my case, meters) are replaced with degrees,
intepreting a "null" geogcs as localcs doesn't help.
Does the GeoTIFF format support localcs? If so, I'd prefer to mod the
driver to actually handle it.
Ray
