[Gdal-dev] Re: s 57 data reader in java
Andrea Aime aaime at openplans.org
Mon Jun 25 08:08:03 EDT 2007
kevser sonmez ha scritto:
>> There are SWIG binginds to GDAL for number of languages,
>> including Java:
>> http://trac.osgeo.org/gdal/wiki/GdalOgrInJava
>> As you will find out, Java bindings are not well documented,
>> so I'd also recommend to search through the gdal-dev list
>> archives:
>> http://news.gmane.org/gmane.comp.gis.gdal.devel
>> where you can find helpful details and hints.
>> Cheers
> Hi,
> thanks a lot for the binding issue, where shall I find the GDAL java bindings,
> do they come with the GDAL installation?
No, they're not in a good enough shape to be included in the GDAL
releases. I suggest you check out gdal trunk, you'll find them there
(and you will have to compile them too).
Cheers
Andrea
