[Gdal-dev] Copying GCPs from one file to another
Ludwig M Brinckmann ludwigbrinckmann at gmail.com
Mon Jun 25 11:38:50 EDT 2007
I have a set of files with GCPs and a set of files that are the result of
processing the first, which lack the GCPs. The files are GeoTiffs and they
have the same shape.
Is there a simple way of getting the GCPs out of the first files and to
attach them to the other?
(Simple means simpler than programmatically reading in the georef'ed file
and the non-georef'ed, extracting the GCPs and rewriting the second set, now
with GCPs)
Ludwig
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20070625/07d735d7/attachment.html
