[Gdal-dev] 16bit Erdas Imagine(HFA) to 8bit GeoTIFF
abhay menon abhay.menon at gmail.com
Wed Jun 27 14:33:30 EDT 2007
Hello List,
I have a 16 Bit (UInt16) Image of Erdas Imagine which I need to convert to a
GeoTIFF file of 8bit (Byte).
I tried using rgb2pct.py and gdal_translate, also did try gdalwarp too. No
success!!
I found on OpenEV (with FWTools 1.3.1) that the raster information suggest
it's color ranges are beyond 255 per band which mean i have to adjust the
color value less than to 255.
Is there any tool or sequence of steps or instruction for gdal_translate or
gdalwarp, which I could follow to adjust the color ranges and convert the 16
bit to 8 bit image.
Best Regards
Abhay Menon
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20070628/caeaa896/attachment.html
