[Gdal-dev] ogrinfo related
kevser sonmez kevsemola at gmail.com
Thu Jun 28 10:36:00 EDT 2007
Hi Frank,
Thanks a lot. The GDAL_DATA just as you told was pointing to a wrong
directory..
I dont remember setting an environment variable though.
Thanks again :)
On 6/28/07, Frank Warmerdam <warmerdam at pobox.com> wrote:
> kevser sonmez wrote:
> > Hi there,
> > I was using ogrinfo.exe without problem yesterday, but today something
> > has happened (as far as I remember I just moved some locations of the
> > files), when I call for an enc-s57 data to look for the naming info of
> > layers with ogrinfo; it always returns of 5 layers like Point, Line,
> > Area... regardless of the data? Yesterday I could be able to get the
> > specific names from the IHO Object Catalogue; like ADMARE, DEPARE ...
> > What do you think may have happened, related with this Object Catalogue?
> Kevser,
> In order to represent object classes properly the OGR S-57 driver needs
> access to the various object catalog files such as s57objectclasses.csv.
> These are normally found in gdal/data in the source.  On windows systems
> you normally have to set the GDAL_DATA environment variable to point to
> the
> directory where these are found.  On Unix this isn't necessary if they
> are installed in the standard location (/usr/local/share/gdal).
> I don't know if you are using FWTools, but if you are it sets up various
> paths at install time, and you can't move things afterwards without fixing
> this up or some things won't work right.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | President OSGeo, http://osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20070628/035b3ed8/attachment.html
