[Gdal-dev] gcore\gdal_rat.cpp typo and logical errors
Fri Jun 29 10:12:05 EDT 2007
Lucena, Ivan wrote:
> Hi there,
> #1 - There is a missing "h" at:
> "In the general case each row as a column indicating the minimum pixel"
> [http://trac.osgeo.org/gdal/browser/trunk/gdal/gcore/gdal_rat.cpp#L54]
> It looks like someone is imitating my writing style :-), but I guess
> that the fix would be:
> "In the general case each row has a column indicating the minimum pixel"
> #2 - And a missing variable assignment to the returning value of a
> function call at:
> 1239             if( iMaxCol == -1 )
> 1240                 GetColOfUsage( GFU_MinMax );
> [http://trac.osgeo.org/gdal/browser/trunk/gdal/gcore/gdal_rat.cpp#L1240]
> The fix is probably something like that:
> 1236             int  iMaxCol;
> 1237
> 1238             iMaxCol = GetColOfUsage( GFU_Max );
> 1240                 iMaxCol = GetColOfUsage( GFU_MinMax );
> 1241
> 1242             if( iMaxCol == -1 || nRowCount == 0 )
> 1243                 return NULL;
> I would be happy to commit it if that is OK.
Ivan,
Yes, you are correct on both points.  I committed the changes
before reading your last line so no need to do so.
Thanks!
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
