[Gdal-dev] Documentation Suggestions
Andrew Bell andrew.bell.ia at gmail.com
Fri Jun 29 17:58:21 EDT 2007
Here are a few suggestions for the OGR documentation:
OGR_G_ExportToWkt()
ppszSrcText 	a text buffer is allocated by the program, and assigned
to the passed pointer.
* "allocated by the program" be better said as "allocated by OGR".
Some note should also say that the buffer should be deallocated with
free() or VSIFree().  (Is there a better way?)
OGR_G_DestroyGeometry
*Some note should be made that a geometry in a feature will be
destroyed when the feature is destroyed and does not need to be
explicitly deallocated with this call.
OGR_L_GetNextFeature
*The documentation says that it is the responsibility of the caller to
delete the object, but it doesn't say how.  Perhaps a reference to
OGR_F_Destroy is in order.  There are other calls that have this same
issue.
OGR_F_Destroy
*The text here is confusing.  You can't free memory _onto_ anywhere,
you can only free memory that has been allocated where it was
allocated.  I'm not sure what this is trying to get across.
Cheers,
Andrew Bell
