[Gdal-dev] Patch to build libecwj2-3.3.tar.gz with GCC 4.1
Daniel Morissette dmorissette at mapgears.com
Thu Mar 1 13:58:15 EST 2007
libecwj2-3.3.tar.gz doesn't build with GCC 4.1, the compilation fails
because of four class method declarations (located in 3 header files)
that are prefixed with the class name. Here is an example of the
compiler error that we get:
./Source/include/NCSJPCBuffer.h:178: error: extra qualification
‘CNCSJPCBuffer::’ on member ‘CNCSJPCBuffer’
./Source/include/NCSJPCBuffer.h:191: error: extra qualification
‘CNCSJPCBuffer::’ on member ‘operator=’
I have attached a patch to this email that solves this. Applying the
patch in the libecwj2-3.3/Source/include directory allows the build to
complete.
Hopefully this fix can be included in the next release of the ECW SDK.
Daniel
Daniel Morissette
http://www.mapgears.com/
Type: text/x-patch
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20070301/3dd3270b/libecw.bin
