[Gdal-dev] Re: [FWTools] Out of Memory error CPLCalloc()
Mateusz Loskot mateusz at loskot.net
Fri Mar 2 14:45:54 EST 2007
Travis Kirstine wrote:
> I've been having problems with reading of .dem and .flt raster with FWTools
> 1.2 with both linux and windows (see below).  To see if the problem was at
> my end I unistalled FWTools and reinstalled a older version that was working
> before and things seemed to work fine  (FWTools 1.0.04a).
Travis,
May be Frank will be able to response in details, but I think we would
need to get the data set that raises the error while you're
processing it. Would it be possible?
Cheers
Mateusz Loskot
http://mateusz.loskot.net
