[Gdal-dev] problem with C# SWIG wrapper
Richard Matsunaga richard.matsunaga at waypointinfo.com
Fri Mar 2 16:58:15 EST 2007
Mateusz,
I am running on Windows. I grabbed the latest release version of GDAL, so
will try with the nightly build to see if anything different happens.
Cheers,
Richard
-----Original Message-----
[mailto:gdal-dev-bounces at lists.maptools.org] On Behalf Of Mateusz Loskot
Sent: March 2, 2007 4:44 PM
To: gdal
Subject: Re: [Gdal-dev] problem with C# SWIG wrapper
Richard Matsunaga wrote:
> I get the same error (without the extended info) when I try to run the
> GDALColorTable.exe that gets created with the build.
Richard,
Do you run it on Linux or Windows?
> Is there some config that I must have missed?
I'll try to test it on my workstations today.
> I think there is a need for a single wiki page for documenting the
> setup for using the C# wrappers along with common pitfalls.
Good point.
I'm sure we will set up one on the Trac.
Cheers
Mateusz Loskot
http://mateusz.loskot.net
Gdal-dev mailing list
Gdal-dev at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/gdal-dev
