[Gdal-dev] problem with C# SWIG wrapper
Tamas Szekeres szekerest at gmail.com
Fri Mar 2 18:26:12 EST 2007
Richard,
Which version of SWIG are you using? Some of the older versions (like
before 1.3.27) do not support %typemap(cscode, noblock="1").
I suggest to use 1.3.29 or later.
Best regards,
Tamas
2007/3/2, Richard Matsunaga <richard.matsunaga at waypointinfo.com>:
> Another oddity that I just rediscovered when building the latest nightly, is
> that there are some extraneous brackets that make my build fail. Removing
> them manually allows me to progress.
> These can be found in Geometry.cs and Band.cs.
> Richard
> -----Original Message-----
> From: Tamas Szekeres [mailto:szekerest at gmail.com]
> Sent: March 2, 2007 4:51 PM
> To: Richard Matsunaga
> Cc: gdal-dev at lists.maptools.org
> Subject: Re: [Gdal-dev] problem with C# SWIG wrapper
> Would you make the tests with the latest SVN or the nightly build?
> Apparently some of the dll-s might not be available to load for your
> application. You might want use Sysinternals filemon to check which files
> could not actually be loaded.
> 'make test' invokes the application in the same directory as the dependent
> dll-s reside.
> Best regards,
> Tamas
> > Hi all,
> > I've just started using the SWIG-generated C# wrapper and can't get it
> > to work. The build seems to run fine, as do the tests, but when
> > actually trying to use the resulting library, I get the following:
> > System.TypeInitializationException : The type initializer for
> > 'GDAL.gdalconst' threw an exception.
> >   ----> System.TypeInitializationException : The type initializer for
> > 'GDAL.gdalconstPINVOKE' threw an exception.
> > 'SWIGExceptionHelper' threw an exception.
> >   ----> System.DllNotFoundException : Unable to load DLL
> > 'gdal_gdalconst_wrap': The specified module could not be found.
> > (Exception from HRESULT: 0x8007007E)
> > I get the same error (without the extended info) when I try to run the
> > GDALColorTable.exe that gets created with the build.
> > Is there some config that I must have missed? I think there is a need
> > for a single wiki page for documenting the setup for using the C#
> > wrappers along with common pitfalls.
> > Thanks,
> > Richard
> > Gdal-dev mailing list
> > Gdal-dev at lists.maptools.org
> > http://lists.maptools.org/mailman/listinfo/gdal-dev
