[Gdal-dev] projection with ogr2ogr
Lijian Shi lijian.shi at und.nodak.edu
Tue Mar 6 16:36:20 EST 2007
Mateusz,
Thank you for your response!
Except WGS84 with epsg 4326, I also want to add the projection information:
PROJCS[" Projection Name = Lambert Azimuthal Equal-ar",
PROJECTION["Lambert_Azimuthal_Equal_Area"],
PARAMETER["latitude_of_center",45],
PARAMETER["longitude_of_center",-100],
PARAMETER["false_easting",0],
PARAMETER["false_northing",0],
UNIT["metre",1,
AUTHORITY["EPSG","9001"]]]
So I tried the command: ogr2ogr -a_srs EPSG:4326 -t_srs "+proj=laea" out.shp
point.shp
And then I get the "header" of shp file as followed:
PROJCS["Lambert_Azimuthal_Equal_Area",
    GEOGCS["GCS_WGS_1984",
        DATUM["unknown",
            SPHEROID["WGS84",6378137,298.257223563]],
        PRIMEM["Greenwich",0],
        UNIT["Degree",0.017453292519943295]],
    PARAMETER["latitude_of_center",0],
    PARAMETER["longitude_of_center",0],
    UNIT["Meter",1]]
But there are still some difference between the "header" of shp file and
geotiff file. I don't know whether my result is right. So look forward to
your suggestion.
Lijian
-----Original Message-----
From: Mateusz Loskot [mailto:mateusz at loskot.net]
Sent: Tuesday, March 06, 2007 10:55 AM
To: Lijian Shi
Cc: gdal-dev at lists.maptools.org
Subject: Re: [Gdal-dev] projection with ogr2ogr
Lijian Shi wrote:
> Now I want to use ogr2ogr to project the shp file in order that the
> shp file has the same geoinformation(same projection, same datum)
> with the geotiff file. I use the command like:
> ogr2ogr -s_srs WGS84 -t_srs EPSG:code utm2.shp point.shp
Lijian,
If I understand you correctly, you have georeferenced GeoTIFF and
you have a Shapefile *without* any referencing.
Now, you have read SRS details from GeoTIFF - it is WGS84 with
EPSG code 4326 - and you want to *assign* the same
one to your Shapefile.
If that's what you want to do, then the command should look as follows:
ogr2ogr -a_srs EPSG:4326 out.shp point.shp
where -a_srs means you want to *assign* SRS to output Shapefile (out.shp).
> Am I right? If right, how can I get the code?
Here is the code, in the GeoTIFF details:
AUTHORITY["EPSG","4326"]],
Cheers
Mateusz Loskot
http://mateusz.loskot.net
