[Gdal-dev] ogrinfo problem
Clay, Bruce bclay at ball.com
Wed Mar 7 10:36:56 EST 2007
I am having trouble opening an KNL file with OGR version 1.2.2 from the
FWTool set.  I have tried both compressed and uncompressed versions an
neither one works
The KML driver is built in based on the error messages shown below.  Is
this a known issue?  I saw one post that said the tool was "write only"
yetsomewhere I thought I saw a different message saying it was read only
unless we had Xerces built in.
H:\SupportLibraries\FWTools1.2.2\bin>ogrinfo
H:\bclay\Download3\GoogleEarth\earthquake_public.kml
FAILURE:
Unable to open datasource
`H:\bclay\Download3\GoogleEarth\geALLFLIGHTS.kmz' with
 the following drivers.
  -> ESRI Shapefile
  -> MapInfo File
  -> UK .NTF
  -> SDTS
  -> TIGER
  -> S57
  -> DGN
  -> VRT
  -> AVCBin
  -> REC
  -> Memory
  -> CSV
  -> GML
  -> KML
  -> Interlis 1
  -> Interlis 2
  -> SQLite
  -> ODBC
  -> PGeo
  -> OGDI
  -> PostgreSQL
  -> MySQL
FAILURE:
  -> ESRI Shapefile
  -> MapInfo File
  -> UK .NTF
  -> SDTS
  -> TIGER
  -> S57
  -> DGN
  -> VRT
  -> AVCBin
  -> REC
  -> Memory
  -> CSV
  -> GML
  -> KML
  -> Interlis 1
  -> Interlis 2
  -> SQLite
  -> ODBC
  -> PGeo
  -> OGDI
  -> PostgreSQL
  -> MySQL
“This message and any enclosures are intended only for the addressee.
Please notify the sender by email if you are not the intended recipient. If you are
not the intended recipient, you may not use, copy, disclose, or distribute this
message or its contents or enclosures to any other person and any such actions
may be unlawful. Ball reserves the right to monitor and review all messages
and enclosures sent to or from this email address."
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20070307/a24afaee/attachment.html
