[Gdal-dev] I/O Performance issues with ENVI data format
Wed Mar 7 14:36:57 EST 2007
Ozy Sjahputera wrote:
> Hi Frank,
> I have to use RasterIO since we try to capture only certain parts of the
> image.  But the buffer size I use is simply the block size prescribed by
> GDAL (if the block size is too large for the area we try to capture, I
> use the smaller size of the two).
> I think the GeoTiff is striped (each block is simply a row of image).
Ozy,
OK, nothing dangerous sounding in how you are doing this.
> Forgive my ignorance, but where and how do you set the GDAL_CACHEMAX
> parameter?
It can be an environment variable, set via the commandline --config
switch or set with the API call GDALSetConfigOption().  For quick
testing the easiest way is to set it in the environment.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
