[Gdal-dev] gdal_translate and Dynamic Range
Wed Mar 7 19:16:56 EST 2007
Gong, Shawn wrote:
> Frank,
> I have similar question: is there a way to save the OpenEV enhanced
> (after scaling) image onto a file, i.e. to capture
> what-I-see-is-what-I-get ?
> I have two images that loaded into OpenEV. I enhance them then fuse the
> two.
> However after fusion all the enhancement is lost.
Shawn,
I'm not sure what method you are using to fuse the images.  Generally
speaking if you can see the image you want, you can "print" it to a file
capturing all the enhancements you see.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
