[Gdal-dev] Kakadu-GDAL building problems on WINDOWS.
Daniele Romagnoli dany.geotools at gmail.com
Fri Mar 9 09:40:47 EST 2007
On 3/9/07, Norman Barker <nbarker at ittvis.com> wrote:
>  Daniele,
> Sorry you got me on a Friday afternoon J , if you add (change the path)
> # Any extra libraries needed on this platform?
> ADD_LIBS = C:\Kakadu\lib\kdu_v51R.lib
> to nmake.opt
I already tried this solution, prior to write my previous email :-(   (After
attempting the "KDULIB" solution :D )
Without success...
Just another question:
Do you used command line NMAKE instead of Visual C++ solution in order to
build your *.obj files?
In such a case, can you show me your kakadu makefile?
I tried editing "Makefile-generic" from "apps/make" and building kakadu
using NMAKE without results...
I think everything should be ok
> Norman
Thanks again.
Best regards,
Daniele Romagnoli
> *From:* Daniele Romagnoli [mailto:dany.geotools at gmail.com]
> *Sent:* 09 March 2007 14:08
> *To:* Norman Barker; gdal-dev at lists.maptools.org; Simone
> *Subject:* Re: [Gdal-dev] Kakadu-GDAL building problems on WINDOWS.
> Norman,
> Thanks a lot for your help.
> I tweaked a bit your makefile since my .obj files (coming from "Visual C++
> solution" Build) are located in several different folders instead of
> "\make".
> (Furthermore, searching in main kakadu folder, I found 11 "jp2.obj" files,
> 6 "jpx.obj" files, ... However,  90% of obj. files having the same name
> (as an instance, 10 jp2.obj files of 11) have the same size. Thus, I
> deduced to use one of them, which are mainly contained in "compress\debug"
> or "expand\debug" folder).
> However, GDAL building process throws many "unresolved external" linking
> errors.
> For almost any external format, NMAKE.OPT defines a couple of variables
> FORMATXX_DIR and a FORMATXX_LIB (Like, as an instance, HDF4_DIR/HDF4_LIB,
> ECWDIR/ECWLIB, and much more...).
> I tried to define a KAKLIB variable linking to kakadu/lib (containing
> kdu_v52D.lib and kdu_a52D lib) but errors still exist.
> Surely, I'm missing something to do or failing some step. :-(
> Can you help me again?
> Thank you very much.
> Best Regards,
> Daniele Romagnoli
>  On 3/9/07, *Norman Barker* <nbarker at ittvis.com > wrote:
> Daniele,
> The attached make file worked for me, but you may have to tweak it.
> Norman
> *From:* gdal-dev-bounces at lists.maptools.org [mailto:
> gdal-dev-bounces at lists.maptools.org] *On Behalf Of *Daniele Romagnoli
> *Sent:* 09 March 2007 12:02
> *To:* gdal-dev at lists.maptools.org; Simone
> *Subject:* [Gdal-dev] Kakadu-GDAL building problems on WINDOWS.
> Hi list,
> I'm trying to build GDAL with kakadu (5.2.2) support under windows XP.
> I have all the required source files (.h, .cpp) and I already built the
> .obj files, using the "ready to use" Visual C++ solutions files
> contained within the kakadu source tree (apps, coresys).
> By analyzing the makefile.vc contained within gdal/frmts/jp2kak, several
> .obj files are required to build GDAL.
> I tried copying "some" .OBJ files to a folder and set this folder in
> NMAKE.OPT.  (With "some" I means .obj files coming from coresys/debug,
> kdu_aux/debug  and something else).
> However, I cant successfully build.
> Can someone help me please, listing the required .obj files?
> Best Regards,
> Daniele
> Best Regards,
> Daniele Romagnoli
Best Regards,
Daniele Romagnoli
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20070309/9ede27ad/attachment.html
