[Gdal-dev] LANDSAT7 format question: GLCF
Mario Beauchamp starged at gmail.com
Fri Mar 9 22:13:29 EST 2007
Hi Markus,
On 3/9/07, Markus Neteler <neteler at itc.it> wrote:
> > The next trick would be to make it read UL, UR, LL, LR...
I kinda remember now that I used vrt files to combine the 321 bands into RGB and
georeference them at the same time and converted to tiff with gdal_translate.
> We made a test with GDAL 1.3.2. It works.
> This indicates that the FAST LANDSAT header file parser
> may be broken in SVN HEAD.
I have to mention that I was using a much older GDAL at the time and
the FAST format
for L7 was not fully implemented. I haven't tried recently...
And historically, GDAL has had probs with some of the GLCF stuff.
cheers
Mario B.
