[Gdal-dev] about shift after reprojection
Lijian Shi lijian.shi at und.nodak.edu
Mon Mar 12 11:33:45 EDT 2007
I use the followed command to reproject a shp file:
ogr2ogr -t_srs WGS84 -s_srs NAD27 out.shp point.shp
Then I overlay the out.shp and point.shp in ArcGIS. But there is some shift
between tow files. Is there any problem with my command?  Thank you very
much for your response.
Best regards,
Lijian
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20070312/ab69fffd/attachment.html
