[Gdal-dev] Layer Coordinate Transformation
ibrahim Z. HIDIR hipoxi at gmail.com
Fri Mar 16 02:10:22 EDT 2007
Hi
When i connect a data source ( with ogr ) i am getting the a layer  first,
then i am putting the layer in a loop and transforming  coordinates all the
features one bye one,
(i am using python )
import ogr
import osr
dss = ogr.Open('OCI:user/pass at db_name')
sqls = 'select * from schema.table'
layer = dss.ExecuteSQL( sqls )
feature = graphics.GetNextFeature()
while feature is not None:
            geom = feature.GetGeometryRef()
            ref       = osr.SpatialReference()
            out_ref = osr.SpatialReference()
            ref.ImportFromWkt( source_coor )      #source coordinate
definition wkt format
            out_ref.ImportFromWkt( base_coor )  # the coordinate system whic
i want to transfom the features in wkt format
            geom.AssignSpatialReference( ref )
            geom.TransformTo(out_ref)
it's working fine, but takes long time when i got a huge data, i couldn't
find a way to transform all layer on one time without a python loop. is
there a way to do it?
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20070316/1608e6bf/attachment.html
