[Gdal-dev] current svn fails to compile, ersdataset.cpp
Howard Butler hobu at iastate.edu
Fri Mar 16 11:42:05 EDT 2007
Fixed.
http://lists.osgeo.org/pipermail/gdal-commits/2007-March/000359.html
On Mar 16, 2007, at 10:29 AM, Thom DeCarlo wrote:
> (I'm sorry if you get this twice. I'm not sure about the first
> address I
> sent it to.)
> I'm getting an error when compiling ersdataset.cpp in the current svn.
> ersdataset.cpp: In static member function 'static GDALDataset*
> ERSDataset::Open(GDALOpenInfo*)':
> ersdataset.cpp:527: error: 'class ERSHdrNode' has no member named
> 'FindElem'
> ersdataset.cpp:533: error: 'class ERSHdrNode' has no member named
> 'FindElem'
> ersdataset.cpp:539: error: 'class ERSHdrNode' has no member named
> 'FindElem'
> ersdataset.cpp:545: error: 'class ERSHdrNode' has no member named
> 'FindElem'
> And, sure enough, it doesn't exist in the ershdrnode.* files. Is
> there a
> check-in missing for this change?
> Thom
> this sig intentionally left blank
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
