[Gdal-dev] SWIG Exceptions for C# Bindings
Tamas Szekeres szekerest at gmail.com
Sat Mar 17 11:43:20 EDT 2007
2007/3/17, Ari Jolma <ari.jolma at tkk.fi>:
> I'd say we should add checks and calls for CPLError for null values like
> this into the bindings layer.
> I did this for a number of methods in ogr.i, for example into
> OGRFeature::GetFieldDefnRef. The simple reason is that if the null gets
> into the scripting language layer, it will create a core dump, which is
> not acceptable behavior, and this is the last place where it can be done
> (at least in the case of Perl). I know there are still many cases in
> which this happens since I get core dumps if I'm careless in coding with
> the Perl bindings.
> Could we adopt the policy of always throwing an exception in a case of
> errors in the bindings?
Generally I have no objection. But why don't we generate the error at
the original place?
Like:
OGRLayer *OGRPGDataSource::GetLayer( int iLayer )
   if( iLayer < 0 || iLayer >= nLayers ) {
       CPLError(CE_Failure, 1, "Invalid argument iLayer in GetLayer");
       return NULL;
   else
       return papoLayers[iLayer];
Best regards,
Tamas
