[Gdal-dev] Segmentation fault
Yves Jacolin yjacolin at free.fr
Sun Mar 18 12:20:15 EDT 2007
Le Dimanche 18 Mars 2007 17:03, Yves Jacolin a écrit :
> Le Dimanche 18 Mars 2007 16:19, Frank Warmerdam a écrit :
> > Yves Jacolin wrote:
> > > Hi,
> > > I built gdal-ogr from source (test 1.3.2 and 1.4.0). I already succeed
> > > to built it. But this time,  I always get this error:
> > > $ gdalinfo --formats
> > > Supported Formats:
> > > Erreur de segmentation (which means Segmentation fault ;-)
> > > I get no error message with configure, make, and make install. I have
> > > no idea where it can come from. My configure command is:
> > > ./configure --without-python --with-sqlite=/usr/include/
> > > --with-mysql=/usr/bin/mysql_config --with-pg=/usr/bin/pg_config
> > > --without-grass --with-ecw=/usr/local/ --with-xerces --without-ogdi
> > > I built gdal-ogr with python and OGDI the last time I succeed, so this
> > > time I tried without, but no change.
> > Yves,
> > One possibility is that you are still building with the old old PROJ.4
> > code in OGDI.  This often causes an othewise unexplainable seg fault with
> > linked into something that also has the modern PROJ.4.  Could you verify
> > that your OGDI is built without the internal PROJ?
> > Best regards,
> Hi Frank,
> Here the ./configure command:
> ./configure --with-proj --with-zlib --with-expat
> so I try to build ogdi with:
> ./configure --with-proj=/usr/local/ --with-zlib --with-expat
> I come back as soon as I finish to test this way.
> Thanks again.
> Y.
I always got this error. The last time I built gdal, I try without-ogdi and
without-python options. I am goint to try to install glda with the minimal
options.
Y.
Yves Jacolin
http://yjacolin.gloobe.org
http://softlibre.gloobe.org
