[Gdal-dev] On Feature.setGeometryDirectly SWIG bindings
Andrea Aime aaime at openplans.org
Sun Mar 18 16:23:51 EDT 2007
Tamas Szekeres ha scritto:
> 2007/3/18, Andrea Aime <aaime at openplans.org>:
>> Hi,
>> playing with java and OGR I had quite a bit of JVM
>> breakages due to inconsistent/conflicting memory
>> handling on either side of the JNI fence.
>> One that has been tricky to identify is Feature.setGeometryDirectly.
>> This issue is there because every SWIG wrapper
>> does deallocate its C++ counterpart when garbage collected,
>> and thus the OGR Feature that got is geometry thru setGeometryDirectly
>> is left with a dangling reference. (since garbage collection is not
>> predictable, the error may occur a few seconds later, leaving
>> you wondering what went wrong).
> You should implement %typemap() SWIGTYPE *DISOWN for the java binding.
> Every wrapper has an internal flag to denote whether the wrapper owns
> the underlying memory and it's responsible to destroy it.
setGeometryDirectly has that typemap afaik, but it's not working as far
as I can see:
%apply SWIGTYPE *DISOWN {OGRGeometryShadow *geom};
   OGRErr SetGeometryDirectly(OGRGeometryShadow* geom) {
     return OGR_F_SetGeometryDirectly(self, geom);
%clear OGRGeometryShadow *geom;
As soon as I try to use setGeometryDirectly my virtual machine goes
bye bye. Using setGeometry works fine instead.
Both java and c# bindings do have a delete() method that allows
to deallocate the native pointer, and the object finalizers
do call delete() always. I don't see that typemap making any difference
there...
Cheers
Andrea
