[Gdal-dev] Projected vs Geographic Coordinate Systems
Simon Perkins sy at perkins.net
Tue Mar 20 00:48:09 EDT 2007
Simon Perkins wrote:
> In a related question, if I have a vector layer in a geographic
> coordinate system, does OGR provide some convenient way to compute the
> relative scaling of degrees in the east-west and north-south
> directions? I guess it comes down to some simple geometry (the size of
> latitude degrees is uniform, the size of longitude degrees go like
> square of cosine of latitude, I think) , but just wondered if there
> was some more sophisticated procedure for what must be a common task.
Er, I mean, longitude degrees go like the cosine of the latitude. Not
sure where the square came from...
This is assuming a sphere of course, but as Frank says, all projections
are lies, so this is probably good enough.
Cheers,
Sy
