[Gdal-dev] Assign projection to a tif image
Tue Mar 20 01:40:05 EDT 2007
Huajun Zhang wrote:
> Hi,
> Is there any method to define a projection to a image rather than
> reproject the image with gdalwarp?
Huajun Zhang,
A projection can be attached to an image in the process of translating
it if the existing projection is wrong or if the input image lacks one
entirely.
For instance,
gdal_translate -a_srs '+proj=utm +zone=11 +datum=WGS84' in.tif out.tif
Is this the sort of operation you had in mind?
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
