[Gdal-dev] Segmentation fault
Yves Jacolin yjacolin at free.fr
Wed Mar 21 05:21:28 EDT 2007
Le Dimanche 18 Mars 2007 17:20, Yves Jacolin a écrit :
> Le Dimanche 18 Mars 2007 17:03, Yves Jacolin a écrit :
> > Le Dimanche 18 Mars 2007 16:19, Frank Warmerdam a écrit :
> > > Yves Jacolin wrote:
> > > > Hi,
> > > > I built gdal-ogr from source (test 1.3.2 and 1.4.0). I already
> > > > succeed to built it. But this time,  I always get this error:
> > > > $ gdalinfo --formats
> > > > Supported Formats:
> > > > Erreur de segmentation (which means Segmentation fault ;-)
> > > > I get no error message with configure, make, and make install. I have
> > > > no idea where it can come from. My configure command is:
> > > > ./configure --without-python --with-sqlite=/usr/include/
> > > > --with-mysql=/usr/bin/mysql_config --with-pg=/usr/bin/pg_config
> > > > --without-grass --with-ecw=/usr/local/ --with-xerces --without-ogdi
> > > > I built gdal-ogr with python and OGDI the last time I succeed, so
> > > > this time I tried without, but no change.
> > > Yves,
> > > One possibility is that you are still building with the old old PROJ.4
> > > code in OGDI.  This often causes an othewise unexplainable seg fault
> > > with linked into something that also has the modern PROJ.4.  Could you
> > > verify that your OGDI is built without the internal PROJ?
> > > Best regards,
> > Hi Frank,
> > Here the ./configure command:
> > ./configure --with-proj --with-zlib --with-expat
> > so I try to build ogdi with:
> > ./configure --with-proj=/usr/local/ --with-zlib --with-expat
> > I come back as soon as I finish to test this way.
> > Thanks again.
> > Y.
> Hi,
> I always got this error. The last time I built gdal, I try without-ogdi and
> without-python options. I am goint to try to install glda with the minimal
> options.
> Y.
My problem doesn't disappear, but do you think that this problem could be due
to the gdal-grass link which have not been updated ?
Thanks,
Y.
Yves Jacolin
http://yjacolin.gloobe.org
