[Gdal-dev] Re: gdalwarp error
Wed Mar 21 15:57:16 EDT 2007
Huajun Zhang wrote:
> Thank you very much, Frank. I met another problem when I use gdalwarp:
> gdalwarp -t_srs '+proj=aea +lat_1=29.50 +lat_2=45.50 +lat_0=23.00
> +lon_0=-96.00 +x_0=0.000 +y_0=0.000 +ellps=GRS80 +units=m +datum=NAD83'
> abl.sid abl.img
> I got the error message:
> ERROR 1: Translating source or target SRS failed: '+proj=aea
> I tried to use C API, I followed the gdalwarp API tutorial, the
> reprojection does not get the correct result either:
>  OGRSpatialReference oSRS;
>  oSRS.SetProjCS( "Albers Conical Equal Area" );
>  oSRS.SetACEA( 29.5, 45.5, 23.0, -96.0, 0.0, 0.0);
>  oSRS.SetWellKnownGeogCS( "NAD83" );
>  oSRS.exportToWkt( &pszDstWKT );
> Do you have any idea?
Huajun,
The error message looks like the issue has to do with quoting.  Are you by
any chance on windows?  If so, you will need to use double quotes to hold
an argument to -t_srs together.
I'm not clear in what way the C API code failed for you.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
