[Gdal-dev] Mosaicing with gdalwarp
Wed Mar 21 21:10:26 EDT 2007
Stephen Woodbridge wrote:
> Quick question. I have been generating tiles with a fixed global
> gridding from CCM files. Obviously along the seams between two adjacent
> CCM files I will generate tiles that have the same spatial extents and
> projection.
> What is the best way to mosaic these tiles?
> gdalwarp --config GDAL_ONE_BIG_READ on infile.tif outfile.tif
> I know that infile.tif and outfile.tif have the same coverage based on
> the file names. All I want to do is mosaic the infile.tif onto
> outfile.tif which exists. Both of these files will have no-data areas
> and data areas.
This should work for what you want.  You may need to use -srcnodata and/or
-dstnodata if these values aren't set properly in the file metadata.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
