[Gdal-dev] compiling with mrsid support
Paul Van Deusen Paul_VanDeusen at uml.edu
Mon Mar 26 15:27:38 EDT 2007
Kirk,
Thanks. That fixed it.
Paul.
Kirk McKelvey wrote:
> Paul,
> This is an incompatibility of our header file with gcc 3.4+; it was not
> considered an error in previous versions of gcc. (Thanks to Mateusz
> Loskot for pointing it out to us originally.)
> To fix the issue in the header (lti_sceneBuffer.h), simply remove the
> extra qualification from the inWindow declaration.  Line 356 should look
> like this:
> bool inWindow(lt_uint32 x, lt_uint32 y) const;
> Kirk.
>> -----Original Message-----
>> From: gdal-dev-bounces at lists.maptools.org
>> [mailto:gdal-dev-bounces at lists.maptools.org] On Behalf Of
>> Paul Van Deusen
>> Sent: Monday, March 26, 2007 11:52 AM
>> To: gdal-dev at lists.maptools.org
>> Subject: [Gdal-dev] compiling with mrsid support
>> Has anyone made notes recently on compiling gdal with mrsid support.
>> Here is what I did so far, but it failed.
>> 1) download the DSDK from LizardTech
>> 2) ./configure --with-mrsid=pathToDSDK
>> 3)edited MRSID lines in nmake.opt to point to the DSDK
>> directory 4)gmake
>> I got this error:
>> /home/pvandeus/downloads/gdal/Geo_DSDK-6.0.7.1407/include/base
>> /lti_sceneBuffer.h:356:
>> error: extra qualification 'LizardTech::LTISceneBuffer::' on
>> member 'inWindow'
>> gmake[2]: *** [../o/mrsiddataset.o] Error 1
>> gmake[2]: Leaving directory
>> `/home/pvandeus/downloads/gdal/gdal-1.4.0/frmts/mrsid'
>> gmake[1]: *** [mrsid-install-obj] Error 2
>> gmake[1]: Leaving directory
>> `/home/pvandeus/downloads/gdal/gdal-1.4.0/frmts'
>> gmake: *** [frmts-target] Error 2
>> This is on a system running Fedora Core 6.
>> Gdal-dev mailing list
>> Gdal-dev at lists.maptools.org
>> http://lists.maptools.org/mailman/listinfo/gdal-dev
Paul Van Deusen
NCASI
600 Suffolk St. Fifth Floor
Lowell, MA 01854
978-934-1948
