[Gdal-dev] compiling with mrsid support
Kirk McKelvey kmckelvey at lizardtech.com
Mon Mar 26 15:36:08 EDT 2007
Whoops, I meant it is an incompatibility with gcc 4.1+, not 3.4+.
> -----Original Message-----
> From: gdal-dev-bounces at lists.maptools.org
> [mailto:gdal-dev-bounces at lists.maptools.org] On Behalf Of
> Kirk McKelvey
> Sent: Monday, March 26, 2007 12:17 PM
> To: Paul_VanDeusen at uml.edu; gdal-dev at lists.maptools.org
> Subject: RE: [Gdal-dev] compiling with mrsid support
> Paul,
> This is an incompatibility of our header file with gcc 3.4+;
> it was not considered an error in previous versions of gcc.
> (Thanks to Mateusz Loskot for pointing it out to us originally.)
> To fix the issue in the header (lti_sceneBuffer.h), simply
> remove the extra qualification from the inWindow declaration.
>  Line 356 should look like this:
> bool inWindow(lt_uint32 x, lt_uint32 y) const;
> Kirk.
> > [mailto:gdal-dev-bounces at lists.maptools.org] On Behalf Of Paul Van
> > Deusen
> > Sent: Monday, March 26, 2007 11:52 AM
> > To: gdal-dev at lists.maptools.org
> > Subject: [Gdal-dev] compiling with mrsid support
> > Has anyone made notes recently on compiling gdal with mrsid support.
> > Here is what I did so far, but it failed.
> > 1) download the DSDK from LizardTech
> > 2) ./configure --with-mrsid=pathToDSDK 3)edited MRSID lines in
> > nmake.opt to point to the DSDK directory 4)gmake
> > I got this error:
> > /home/pvandeus/downloads/gdal/Geo_DSDK-6.0.7.1407/include/base
> > /lti_sceneBuffer.h:356:
> > error: extra qualification 'LizardTech::LTISceneBuffer::' on member
> > 'inWindow'
> > gmake[2]: *** [../o/mrsiddataset.o] Error 1
> > gmake[2]: Leaving directory
> > `/home/pvandeus/downloads/gdal/gdal-1.4.0/frmts/mrsid'
> > gmake[1]: *** [mrsid-install-obj] Error 2
> > gmake[1]: Leaving directory
> > `/home/pvandeus/downloads/gdal/gdal-1.4.0/frmts'
> > gmake: *** [frmts-target] Error 2
> > This is on a system running Fedora Core 6.
> > Gdal-dev mailing list
> > Gdal-dev at lists.maptools.org
> > http://lists.maptools.org/mailman/listinfo/gdal-dev
