[Gdal-dev] patch for ngpython on windows using mingw
Howard Butler hobu at iastate.edu
Mon Mar 26 21:57:11 EDT 2007
On Mar 26, 2007, at 8:48 PM, Rob McMullen wrote:
> I couldn't figure out how to get distutils to report which compiler it
> was using, so I had to assume that if you're on windows and the
> GDALmake.opt file exists, then you're really using the mingw compiler.
Seems like as reasonable way as any to discriminate.  Patch applied
to head.
Thanks,
Howard
