[Gdal-dev] patch for ngpython on windows using mingw
Mon Mar 26 23:17:12 EDT 2007
Howard Butler wrote:
> On Mar 26, 2007, at 8:48 PM, Rob McMullen wrote:
>> I couldn't figure out how to get distutils to report which compiler it
>> was using, so I had to assume that if you're on windows and the
>> GDALmake.opt file exists, then you're really using the mingw compiler.
> Seems like as reasonable way as any to discriminate.  Patch applied to
> head.
Rob / Howard,
How does it distinguish this case from the case of a Cygwin build? Or
for these purposes is a pure cygwin build similar to a mingw build?
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
