[Gdal-dev] GDAL with VB.net (VS 2005 Express)
Tamas Szekeres szekerest at gmail.com
Tue Mar 27 08:35:11 EDT 2007
You can use the GDAL C# API for this purpose. If you don't want to
bother with the complilation the required dll-s can be obtained from
the latest FWTools package.
If you would like to compile the binaries, you should checkout the
source from the SVN or use the nightly snapshot. The latter contains
all of the pregenerated interface files ready to compile with VS2005.
The gdal/swig/csharp/apps directory contains some examples how to use
the various features of the GDAL/OGR API.
Best regards,
Tamas Szekeres
2007/3/27, Milo van der Linden <milo at 3dsite.nl>:
> Hello list,
> I am pretty new to GDAL development and no hardcore C++ developer. What
> I want is to compile GDAL to use it in a VB.net application. I have the
> same wish for PROJ, but I understand this is not the list to discuss
> that topic on.
> What I am looking for is getting a GDAL dll that opens all the GDAL
> functions, properties and methods to my Visual Basic application. Right
> now I do the trick partially by using MapWinGIS, but I find their GDAL
> implementation lacking functions that I need.
> Are there any good wrappers, assemblies or project files for Visual
> Studio Express around for the latest (from source) version of GDAL?
> Has anyone got good experience with implementing these in Visual Basic
> .net on Visual Studio 2005 Express?
> Kind regards,
> Milo van der Linden
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
