[Gdal-dev] GDAL MSVC files updated for 1.4.0
Ivan Lucena ivan at ilucena.net
Tue Mar 27 10:41:53 EDT 2007
Ben,
I also whould like to thank you for the VC project. I used your <File> tree in the "Makefile Project" (gdal\makegdalNN.vcproj).
There are obvious advantages of using the Ben's VC2005 project but it is a little harder to maintain compatibility with the current makefile.vc.
In the "Makefile Project" the absence of a source file will not affect the compilation because it runs "make -f makefile.vc" anyway. Some of the code completing works, some doesn't; Clicling in the sintax error not always "Go to location".
Zhonghai,
I suggest you try to use the makegdal80.vcproj to see if attends you needs:
http://trac.osgeo.org/gdal/browser/trunk/gdal/makegdal80.vcproj
Frank,
Since Mateusz has approved the use of the VC "Makefile Project" can I add a line in the wiki page about it?
Thanks,
Ivan
----- Original Message -----
To: "Frank Warmerdam"
Subject: Re: [Gdal-dev] GDAL MSVC files updated for 1.4.0
Date: Tue, 27 Mar 2007 09:58:41 +0200
Hi Ben,
thanks for the efforts to make a solution for VS2005. Maybe you forget to set the Additional Include Directories for the project gdal_rasterrize, it should be set like "..\..\alg;..\..\frmts;..\..\gcore;..\..\ogr;..\..\port".
I build it successfully after setting the include paths.
Zhonghai
On 3/27/07, Frank Warmerdam <warmerdam at pobox.com> wrote: Ben Discoe wrote:
> For those using GDAL on Windows, you may know that the GDAL build
> documentation:
>   http://gdal.org/gdal_building.html
Ben and others,
This page actually moved to the wiki today, though your pointer was enough
for me to realize my www.gdal.org web site update script was broken.
See:
  http://trac.osgeo.org/gdal/wiki/BuildingOnWindows
Users, developers, etc are encouraged to improve this as needed.
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
Gdal-dev mailing list
Gdal-dev at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/gdal-dev
