[Gdal-dev] what is "band configurations"?
Maciej Sieczka tutey at o2.pl
Tue May 1 14:08:28 EDT 2007
Matt Wilkie wrote:
> With regard to rewriting that page, balancing detail which will confuse
> against more information: The 1 or 3 band info is actually in there
> twice right now, which may have contributed to Maciej's original
> confusion. How about simply removing the second instance under "Creation
> Options", since the band configuration is not actually a -co anyway?
> Creation Options
> JPEG files are created using the "JPEG" driver code. JPEG file creation
> is implemented by the batch (CreateCopy) method.
Anyway, I'd vote for more documentation against less, if that's not too
much trouble.
Cheers,
Maciek
