[Gdal-dev] GDALWarpOptions padfSrcNoDataImag
Wed May 2 18:21:08 EDT 2007
Craig Miller wrote:
> I'm getting an exception in GDALWarpOperation when I initialize with my warp
> options.  The exception is getting thrown when Initialize verifies that
> padfSrcNoDataImag[0] isn't 0 since padfSrcNoDataImag is NULL.  I can of
> course tweak gdal to check for a NULL pointer instead of looking for 0 in
> the 0 index, but without digging further I'm not 100% that is ok.  I've
> processed several hundred files with my code the way it is, and it is only
> this new image that is giving me fits so I thought I'd first try and
> determine what the padfSrcNoDataImag option is.  With a cursory look at the
> docs I haven't been able to find a description of how/why this gets set.
> Any suggestions?
Craig,
I don't know why this would only affect one image out of many similar ones.
But I do think this code in Initialize() should not assume padfSrcNoDataImag
is non-NULL just because padfSrcNoDataReal is non-NULL
             if( hSrcBand != NULL
                 && psOptions->padfSrcNoDataReal != NULL )
                 int bMergeSource = FALSE;
                 if( psOptions->padfSrcNoDataImag[iBand] != 0.0
                     && !GDALDataTypeIsComplex( psOptions->eWorkingDataType ) )
                     bMergeSource = TRUE;
Could you file a bug on this, and I'll fix it in trunk and 1.4 branch.  I
think the fix would be to change:
to:
                 if( psOptions->padfSrcNoDataImag != NULL
                     && psOptions->padfSrcNoDataImag[iBand] != 0.0
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
