[Gdal-dev] GRIB Driver status
Daniel daniel112b at gmail.com
Thu May 3 15:07:24 EDT 2007
This is probably happens because GDAL can't find PROJ.4 (proj.dll).
You can get that from:
http://www.remotesensing.org/proj/
There are prebuilt binaries for win32 ready to go.
Regards,
  Daniel Bäck
On 5/3/07, Andrea Battisti <battisti at actgate.com> wrote:
> >> I'm interested in testing and track the progress of the GDAL GRIB
> >> driver.
> >> How can I download the latest code for the driver in order to compile
> >> and test it?
> > Andrea,
> > Sorry, there was a slight reorganization of the subversion repository.
> > Now you would do:
> >   svn checkout https://svn.osgeo.org/gdal/spike/grib grib
> Thanks, the new link worked fine...
> I've compiled on Windows the GRIB driver along with the latest svn
> snapshot of GDAL.
> When I try to load sample GRIB data, I get this:
> Warning/Error: 6: Failed to initialize PROJ.4 with `+proj=lcc +lat_1=0
> +lat_2=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=6371200 +b=6371200 +units=m
> +no_defs '.
> Then the resulting image seems not to have correct/valid values.
> Any hints on what this warrning/error could be related to?
> Anyone successfully using the GRIB driver on Windows?
> Thanks for any help/advice...
> Kind regards,
> Andrea Battisti, ACT Corp.
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
