[Gdal-dev] Unable to load PROJ.4 library in GDAL
Ari Jolma ari.jolma at tkk.fi
Fri May 4 04:43:17 EDT 2007
Roger André kirjoitti:
> I then edited the /etc/profile dir in Cygwin and added the following
> entry:
> PROJSO=/cygdrive/c/FWTools1.2.2/bin/proj_fw.dll
> After sourcing /etc/profile the environment variable appeared to be
> correctly set.  I then tested the gdalwarp, and again got the same error.
I think PROJSO should be set to just "proj_fw.dll" in your case. That's
because GDAL uses a system call for loading a dll with its name. The
system then looks through the usual places, which you have told it using
PATH. Is /cygdrive/c/FWTools1.2.2/bin/ in your PATH?
Ari
Prof. Ari Jolma
Geoinformaatio- ja paikannustekniikka / Geoinformation and positioning
Teknillinen Korkeakoulu / Helsinki University of Technology
tel: +358 9 451 3886 address: POBox 1200, 02015 TKK, Finland
Email: ari.jolma at tkk.fi URL: http://www.tkk.fi/~jolma
