[Gdal-dev] Memory Leak with SpatialReference class in C# bindings
    Tamas Szekeres
    szekerest at gmail.com
    Fri May  4 11:59:08 EDT 2007
Would you submit a ticket and adding your test example?
Best regards,
Tamas
2007/5/4, Jason Beverage <jbeverage at prologic-inc.com>:
> All,
> I've been looking at the C# bindings to see if we can use them in our
> project and I noticed that there seems to be a memory leak when using
> the SpatialReference class.  I'm not sure this same problem exists
> elsewhere, but it is something to look into.
> Running the following simple loop makes memory go through the roof even
> though Dispose is being called
> for (int i = 0; i < 1000000; ++i)
>   using (SpatialReference dst = new SpatialReference(""))
>     //Do something with SpatialReference
> I looked through the bindings quickly this morning and didn't see
> anything glaringly obvious, should I file a ticket for this problem?
> Thanks!
> Jason
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
