[Gdal-dev] RFC 12: Improved File Management
Mon May 7 21:51:49 EDT 2007
Ray Gardener wrote:
> An issue here is that the returned filenames might not refer to files,
> unless you know which VSI*L filesyshandler was used. Usually this
> assumption is harmless -- the default handler is assigned at compile
> time and set to use the machine's normal filesystem -- but when one
> starts using other filesyshandlers (like you said, for mem and so
> forth), then the assumption breaks.
> If we want to enumerate and manage the physical entities in a dataset
> regardless of how their storage is implemented, and add entity
> management methods to GDALDataSet, the dataset needs to know how the
> entities were stored. But storage details lie outside the driver. The
> driver would need to forward an entity management call to the same
> filesyshandler that originally wrote the entity.
> So what we need is to have datasets know which filesyshandler they are
> using. The driver's methods need an extra filesyshandler parameter,
> which they can forward to datasets as part of the openinfo or something
> similar. VSIFOpenL() needs to take a filesyshandler parameter, or
> drivers should be able to call VSIFilesystemHandler::Open().
Ray,
The current virtual file system stuff is handled by installing a global
IO handler for a particular aspect of the filesystem namespace.  So,
for instance, the "in memory filesystem" stuff is all in the filesystem
area under /vsimem/.  Filesystem handlers are globally installed.  So
I don't see any need to make the file system handler apparent by
specifically passing it into Create() methods or to VSIOpenL().
> Then I could pass a filesyshandler subclass to driver::Create(), and
> have the dataset do all of it's I/O with it, and know which
> filesyshandler to use when doing entity management.
> Issues like subdatasets could then be handled by treating the base
> dataset as a filesystem, and implementing a filesyshandler for that
> dataset's format.
I think there are two levels of indirection implicit in your statement.
One is at the VSI*L level which is raw binary data.  But subdatasets are
really a GDAL concept and their meaning vary from format to format.  I'm
not sure how to mesh this all.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
