[Gdal-dev] "Could not allocate enough memory" when translating VRT to ECW
Asger Sigurd Petersen ASP at blominfo.dk
Tue May 8 03:50:38 EDT 2007
Dear Frank,
While the error persists on my primary computer (WinXp 2GB Ram), I
haven't been able to reproduce the error on my other available computer
(Win64 3GB Ram). So I guess the error is somewhat hardware related,
which I think makes it difficult to file a decent bug report.
I'll give up for now, but I might return to the issue at a later time.
Best regards
Asger
-----Original Message-----
From: Frank Warmerdam [mailto:warmerdam at pobox.com]
Sent: 2. maj 2007 15:45
To: Asger Sigurd Petersen
Cc: gdal-dev at lists.maptools.org
Subject: Re: [Gdal-dev] "Could not allocate enough memory" when
Asger Sigurd Petersen wrote:
> Dear list,
> While experimenting with compression of vrt-files, I've run into the
> following error:
> D:\tmp>gdal_translate -of ECW --config ECW_LARGE_OK YES -co TARGET=90
> -co DATUM=WGS84 -co PROJ=NUTM32 mosaic.vrt mosaic.ecw
> Input file size is 263092, 246181
> 0..ERROR 1: An error has occurred: Error 46 "Could not allocate enough
> memory"
> file "" line 0
> ERROR 1: IReadBlock failed at X offset 0, Y offset 15825
> ERROR 1: GetBlockRef failed at X block offset 0, Y block offset 15825
> 100 - done.
Asger,
If you can file a bug sufficient for us to reproduce this, I could have
Mateusz do some digging.  But it seems like the problems is deep in the
ECW SDK and it likely to be very hard for us to ferret out.
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam,
and watch the world go round - Rush    | President OSGeo,
http://osgeo.org
