[Gdal-dev] HDF4 format read in - command line ?
Hannes Isaak Reuter hannes.reuter at jrc.it
Tue May 8 09:29:10 EDT 2007
     Today i got an HDF4 format dataset to help on and somehow I'm to
     stupid to tell my colleagues to tell how to read it in..
     Usually I was reading it using the gdalinfo,
     identifying the
     SUBDATASET_1_NAME
     and than use that for the gdalwarp process..
     with that HDF file now i have no idea how to call the substring. and
     after playing around for 3 hours with different combinations i
     deccide to call for help..
     If anybody can tell me the file/band string from the gdalinfo command
     given below, i'm quite happy ..
     U:\share\Luis>gdalinfo GEO2004001.hdf
     Driver: HDF4Image/HDF4 Dataset
     Size is 11277, 3086
     Coordinate System is:
     GEOGCS["Unknown datum based upon the Clarke 1866 ellipsoid",
          DATUM["Not specified (based on Clarke 1866 spheroid)",
              SPHEROID["Clarke 1866",6378206.4,294.9786982139006,
- Ignored:
                  AUTHORITY["EPSG","7008"]]],
          PRIMEM["Greenwich",0],
          UNIT["degree",0.0174532925199433]]
     Origin = (-29.238043888889045,70.000000000000000)
     Pixel Size = (0.012964385918241,-0.012964386026500)
     Metadata:
        HDFEOSVersion=HDFEOS_V2.6
        OldStructMetadata.0=GROUP=SwathStructure
     END_GROUP=SwathStructure
     GROUP=GridStructure
              GROUP=GRID_1
                      GridName="MOD_Grid_monthly_1km_VI"
                      XDim=6000
                      YDim=4800
                      UpperLeftPointMtrs=(-1111950.519667,7783653.637667)
                      LowerRightMtrs=(4447802.078667,3335851.559000)
                      Projection=GCTP_SNSOID
                      ProjParams=(6371007.181000,0,0,0,0,0,0,0,0,0,0,0,0)
                      SphereCode=-1
                      GridOrigin=HDFE_GD_UL
                      GROUP=Dimension
                      END_GROUP=Dimension
                      GROUP=DataField
                              OBJECT=DataField_1
                                      DataFieldName="1 km monthly NDVI"
                                      DataType=DFNT_INT16
                                      DimList=("YDim","XDim")
                              END_OBJECT=DataField_1
                      END_GROUP=DataField
                      GROUP=MergedFields
                      END_GROUP=MergedFields
              END_GROUP=GRID_1
     END_GROUP=GridStructure
     GROUP=PointStructure
     END_GROUP=PointStructure
     END
        OldArchiveMetadata.0=
     GROUP                  = ARCHIVEDMETADATA
        GROUPTYPE            = MASTERGROUP
        OBJECT                 = CHARACTERISTICBINANGULARSIZE
          NUM_VAL              = 1
          VALUE                = 30.000000
        END_OBJECT             = CHARACTERISTICBINANGULARSIZE
        OBJECT                 = CHARACTERISTICBINSIZE
          NUM_VAL              = 1
          VALUE                = 926.625433
        END_OBJECT             = CHARACTERISTICBINSIZE
        OBJECT                 = DATACOLUMNS
          NUM_VAL              = 1
          VALUE                = 1200
        END_OBJECT             = DATACOLUMNS
        OBJECT                 = DATAROWS
          NUM_VAL              = 1
          VALUE                = 1200
        END_OBJECT             = DATAROWS
        OBJECT                 = GLOBALGRIDCOLUMNS
          NUM_VAL              = 1
          VALUE                = 43200
        END_OBJECT             = GLOBALGRIDCOLUMNS
        OBJECT                 = GLOBALGRIDROWS
          NUM_VAL              = 1
          VALUE                = 21600
        END_OBJECT             = GLOBALGRIDROWS
        OBJECT                 = NUMBEROFDAYS
          NUM_VAL              = 1
          VALUE                = 48
        END_OBJECT             = NUMBEROFDAYS
        OBJECT                 = DAYSOFYEAR
          NUM_VAL              = 48
          VALUE                = (353, 354, 355, 356, 357, 358, 359, 360,
     361, 362, 36
     3, 364, 365, 366, 1, 2, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13,
     14, 15, 16, 1
     7, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32)
        END_OBJECT             = DAYSOFYEAR
        OBJECT                 = NUMBEROF16DAYPERIODS
          NUM_VAL              = 1
          VALUE                = 3
        END_OBJECT             = NUMBEROF16DAYPERIODS
        OBJECT                 = SPSOPARAMETERS
          NUM_VAL              = 4
          VALUE                = ("2749", "4334", "2749a", "4334a")
        END_OBJECT             = SPSOPARAMETERS
        OBJECT                 = GEOANYABNORMAL
          NUM_VAL              = 1
          VALUE                = "False"
        END_OBJECT             = GEOANYABNORMAL
        OBJECT                 = GEOESTMAXRMSERROR
          NUM_VAL              = 1
          VALUE                = 50.000000
        END_OBJECT             = GEOESTMAXRMSERROR
        OBJECT                 = INSTRUMENTNAME
          NUM_VAL              = 1
          VALUE                = "Moderate-Resolution Imaging
SpectroRadiometer"
        END_OBJECT             = INSTRUMENTNAME
        OBJECT                 = PROCESSINGCENTER
          NUM_VAL              = 1
          VALUE                = "MODAPS"
        END_OBJECT             = PROCESSINGCENTER
        OBJECT                 = INPUTFILENAME
          NUM_VAL              = 3
          VALUE                =
     ("MOD13A2.A2004353.h17v02.004.2005008091125.hdf", "MO
     D13A2.A2005001.h17v02.004.2005027190904.hdf",
     "MOD13A2.A2005017.h17v02.004.20050
     39040318.hdf")
        END_OBJECT             = INPUTFILENAME
        OBJECT                 = PERCENTLAND
          NUM_VAL              = 1
          VALUE                = 0
        END_OBJECT             = PERCENTLAND
        OBJECT                 = SEAPROCESSED
          NUM_VAL              = 1
          VALUE                = "Yes"
        END_OBJECT             = SEAPROCESSED
        OBJECT                 = PROCESSINGENVIRONMENT
          NUM_VAL              = 1
          VALUE                = "IRIX64 mtvs1 6.5 10070055 IP35"
        END_OBJECT             = PROCESSINGENVIRONMENT
        OBJECT                 = DESCRREVISION
          NUM_VAL              = 1
          VALUE                = "4.1"
        END_OBJECT             = DESCRREVISION
        OBJECT                 = LONGNAME
          NUM_VAL              = 1
          VALUE                = "MODIS/Terra Vegetation Indices Monthly
     L3 Global 1km
       SIN Grid"
        END_OBJECT             = LONGNAME
        GROUP                  = BOUNDINGRECTANGLE
          OBJECT                 = NORTHBOUNDINGCOORDINATE
            NUM_VAL              = 1
            VALUE                = 70.000000
          END_OBJECT             = NORTHBOUNDINGCOORDINATE
          OBJECT                 = SOUTHBOUNDINGCOORDINATE
            NUM_VAL              = 1
            VALUE                = 30.000000
          END_OBJECT             = SOUTHBOUNDINGCOORDINATE
          OBJECT                 = EASTBOUNDINGCOORDINATE
            NUM_VAL              = 1
            VALUE                = 62.24191
          END_OBJECT             = EASTBOUNDINGCOORDINATE
          OBJECT                 = WESTBOUNDINGCOORDINATE
            NUM_VAL              = 1
            VALUE                = -29.238044
          END_OBJECT             = WESTBOUNDINGCOORDINATE
        END_GROUP              = BOUNDINGRECTANGLE
        OBJECT                 = QAPERCENTPOORQ1KMMONTHNDVI
          NUM_VAL              = 16
          VALUE                = (0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
0, 0, 0, 100)
        END_OBJECT             = QAPERCENTPOORQ1KMMONTHNDVI
        OBJECT                 = QAPERCENTPOORQ1KMMONTHEVI
          NUM_VAL              = 16
0, 0, 0, 100)
        END_OBJECT             = QAPERCENTPOORQ1KMMONTHEVI
        OBJECT                 = COMPOSITEMONTHNAME
          NUM_VAL              = 1
          VALUE                = "January"
        END_OBJECT             = COMPOSITEMONTHNAME
     END_GROUP              = ARCHIVEDMETADATA
     END
     Corner Coordinates:
     Upper Left  ( -29.2380439,  70.0000000) ( 29d14'16.96"W, 70d 0'0.00"N)
     Lower Left  ( -29.2380439,  29.9919047) ( 29d14'16.96"W, 29d59'30.86"N)
     Upper Right ( 116.9613361,  70.0000000) (116d57'40.81"E, 70d 0'0.00"N)
     Lower Right ( 116.9613361,  29.9919047) (116d57'40.81"E, 29d59'30.86"N)
     Center      (  43.8616461,  49.9959524) ( 43d51'41.93"E, 49d59'45.43"N)
     Band 1 Block=11277x1 Type=Int16, ColorInterp=Gray
     U:\share\Luis>
- Done.
Received: from mx2.jrc.it (mx2.jrc.it [139.191.1.110])
	by duke.maptools.org (8.12.11/8.12.10) with ESMTP id l48DQMvH008039
	for <gdal-dev-request at lists.maptools.org>;
	Tue, 8 May 2007 09:26:35 -0400
Received: from irelay.jrc.it (irelay.jrc.it [139.191.254.63])
	by mx2.jrc.it (LMC5614Amx2) with ESMTP id l48DQEua006460
	Tue, 8 May 2007 15:26:14 +0200 (CEST)
Received: from cheetah-1.jrc.it (cheetah-1.jrc.it [139.191.243.17])
	by irelay.jrc.it (LMC5614Ainternal) with ESMTP id l48D8rq8007957
	Tue, 8 May 2007 15:26:13 +0200 (MEST)
Received: from D01RI0302803.jrc.it (139.191.16.37) by cheetah-1.jrc.it
	(7.1.006) (authenticated as hannes.reuter)
	id 45C0D425001A35E6 for gdal-dev-request at lists.maptools.org;
	Tue, 8 May 2007 15:25:48 +0200
Message-ID: <45C0D425001A35E6 at cheetah-1.jrc.it> (added by postmaster at jrc.it)
X-Mailer: QUALCOMM Windows Eudora Version 7.1.0.9
Date: Tue, 08 May 2007 15:26:07 +0200
To: gdal-dev-request at lists.maptools.org
From: Hannes Isaak Reuter <hannes.reuter at jrc.it>
Subject: HDF4 format read in - command line ?
Mime-Version: 1.0
Content-Type: text/plain; charset="us-ascii"; format=flowed
X-Spam-Status: No, score=-101.2 required=99.0 tests=ALL_TRUSTED,AWL,
	UPPERCASE_50_75,USER_IN_WHITELIST autolearn=disabled version=3.1.1
X-Spam-Checker-Version: SpamAssassin 3.1.1 (2006-03-10) on mx2.jrc.it
Dear colleagues..
identifying the
SUBDATASET_1_NAME
Size is 11277, 3086
Metadata:
GROUP=GridStructure
         GROUP=GRID_1
                 XDim=6000
                 YDim=4800
                 SphereCode=-1
                 GROUP=Dimension
                 END_GROUP=Dimension
                 GROUP=DataField
                         OBJECT=DataField_1
                                 DataType=DFNT_INT16
                 END_GROUP=DataField
                 GROUP=MergedFields
         END_GROUP=GRID_1
END
     NUM_VAL              = 1
     VALUE                = 30.000000
     NUM_VAL              = 1
     VALUE                = 926.625433
     NUM_VAL              = 1
     VALUE                = 1200
   OBJECT                 = DATAROWS
     NUM_VAL              = 1
     VALUE                = 1200
     NUM_VAL              = 1
     VALUE                = 43200
     NUM_VAL              = 1
     VALUE                = 21600
     NUM_VAL              = 1
     VALUE                = 48
   OBJECT                 = DAYSOFYEAR
     NUM_VAL              = 48
361, 362, 36
14, 15, 16, 1
     NUM_VAL              = 1
     VALUE                = 3
     NUM_VAL              = 4
     NUM_VAL              = 1
     VALUE                = "False"
     NUM_VAL              = 1
     VALUE                = 50.000000
     NUM_VAL              = 1
     VALUE                = "Moderate-Resolution Imaging SpectroRadiometer"
     NUM_VAL              = 1
     VALUE                = "MODAPS"
     NUM_VAL              = 3
     VALUE                =
39040318.hdf")
     NUM_VAL              = 1
     VALUE                = 0
     NUM_VAL              = 1
     VALUE                = "Yes"
     NUM_VAL              = 1
     NUM_VAL              = 1
     VALUE                = "4.1"
   OBJECT                 = LONGNAME
     NUM_VAL              = 1
L3 Global 1km
  SIN Grid"
       NUM_VAL              = 1
       VALUE                = 70.000000
       NUM_VAL              = 1
       VALUE                = 30.000000
       NUM_VAL              = 1
       VALUE                = 62.24191
       NUM_VAL              = 1
       VALUE                = -29.238044
     NUM_VAL              = 16
     VALUE                = (0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 100)
     NUM_VAL              = 16
     NUM_VAL              = 1
     VALUE                = "January"
END
Corner Coordinates:
U:\share\Luis>
