[Gdal-dev] Re: Problem using EPSG in C#
Tomas R monshi at home.se
Wed May 9 05:26:55 EDT 2007
Tamas Szekeres skrev:
> Tomas,
> Thank you for the detailed analysis of the problem. I'm working on
> this issue and will notify you if I have further information. In the
> meantime I would suggest to submit a ticket including the example
> code.
> http://trac.osgeo.org/gdal/newticket
> Best regards,
> Tamas Szekeres
Ok, done that. Included as specific info as I could.
You should be able to reproduce it.
Thanks
Tomas
