[Gdal-dev] Read image file to Numpy, then output to image
    Christopher Barker
    Chris.Barker at noaa.gov
    Wed May  9 12:23:08 EDT 2007
Nate Jennings wrote:
>  >From other posts in other mail lists, I have been encouraged to look
> at gdal for loading a multi-band image file into numpy, process it, then
> write it out to an image format.
That may have been me ;-)
> img = gdal.gdal.Open('c:\\nate\\remote_sensing\\pyth_img_test.tif',
> GA_ReadOnly)
> AttributeError: 'module' object has no attribute 'gdal'
you've got an extra "gdal" in there:
img = gdal.Open(.....
> if
> I am having difficulty with loading libraries, having to change path
> variables, etc, then this is too much for the novie Remote Sensing
> student.
Once you've got it figured out, you should be able make it as simple as
running some installers. Or maybe you can py2exe an app, and really make
it easy.
   I am not into compiling my own libraries and will be pushing
> my programming limits with writing C++, binding python to c++ code,
> etc.
I'm guessing you can do a lot of what you want without using C++.
I got a little lost in your explanation of what you really need, but
we'll certainly help with how to accomplish specific tasks.
Try the above, and see how far you get.
-Chris
Christopher Barker, Ph.D.
Oceanographer
Emergency Response Division
NOAA/NOS/OR&R            (206) 526-6959   voice
7600 Sand Point Way NE   (206) 526-6329   fax
Seattle, WA  98115       (206) 526-6317   main reception
