[Gdal-dev] Re: Problem using EPSG in C#
Tamas Szekeres szekerest at gmail.com
Wed May 9 18:25:32 EDT 2007
Tomas,
You'll have to comment out the
CSHARP_STATIC_LINKAGE = YES
in csharp.opt and recompile the C# interface. Using this setting the
csharp dll-s will link against the gdal14.dll so the
PushFinderLocation and ImportFromEPSG will operate on the same global
data. In the future I consider to use this setting as the default
option.
BTW: I would propose to use the latest development version of the C#
related stuff. There were some fundamental changes in the interface
that might cause some changes in the existing code. For more
information see:
http://trac.osgeo.org/gdal/wiki/GdalOgrCsharpVersions
You might also use the binaries of the latest FWTools
http://test.gdal.org/fwtools/FWTools130.exe
and replace the *_wrap.dll-s and *_csharp.dll-s inside with the
compiled version.
Best regards,
Tamas
2007/5/9, Tomas R <monshi at home.se>:
> Tomas R skrev:
> > Tamas Szekeres skrev:
> >> Tomas,
> >> Thank you for the detailed analysis of the problem. I'm working on
> >> this issue and will notify you if I have further information. In the
> >> meantime I would suggest to submit a ticket including the example
> >> code.
> >> http://trac.osgeo.org/gdal/newticket
> >> Best regards,
> >> Tamas Szekeres
> > Ok, done that. Included as specific info as I could.
> > You should be able to reproduce it.
> > Thanks
> > Tomas
> For those interested the ticket number is 1621. Just click the link to
> read the ticket:
> http://trac.osgeo.org/gdal/ticket/1621
> Hope this will be solved sometime soon. I have other things to attack in
> my code so just knowing this is under review is, for now, good enough
> for me.
> /Tomas
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
