[Gdal-dev] Dealing with a GeoTiff with incorrect band ColorInterp values
Thu May 10 10:12:32 EDT 2007
Ben Greene wrote:
> ERROR 5: GDALDataset::GetRasterBand(2) - Illegal band #
> ERROR 5: GDALDataset::GetRasterBand(3) - Illegal band #
> ERROR 5: panDstBands[1] = 2 ... out of range for dataset.
> I don’t want my program to modify the original image, just in case RGB
> isn’t the correct interpretation, and don’t want to have to copy the
> image, fix the ColorInterp values, and then warp it to create a third copy.
Ben,
My understanding is that the core problem is that you are using gdalwarp
and it is failing.  Is that right?  If so, could you provide the gdalinfo
report on the input file, and the exact commandline for gdalwarp that
you are using?
 > Is there an option to force RGB interpretation of bands in a Tiff?  Or
 > do I have to correct the ColorInterp values?
When creating a new TIFF or GeoTIFF file you should be able to use the
PHOTOMETRIC=RGB creation option to force the output file to be marked
as RGB.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
