[Gdal-dev] Re: Problem using EPSG in C#
Tamas Szekeres szekerest at gmail.com
Thu May 10 17:14:38 EDT 2007
Oops!  Some recent changes in gdal have been interfering with this
setting. I've now fixed up the problem in the gdal-trunk and set the
default option to link the C# dll-s dynamically to the gdal libraries.
Please, checkout the latest version and repeat your tests.
It must be noted that after this change the gdal14.dll should be
available to load when running the application or the 'nmake -f
makefile.vc test' target.
Best regards,
Tamas
2007/5/10, Tomas R <monshi at home.se>:
> I thought  I had the issue solved, that I had managed to compile the
> correct C# bindings and so on.
> But, sadly no.
> What have I got?
> FWtools 3.0
> Gdal source, from the latest Trunk
> Got the whole SDK-kit from MS, Swig 1.3.31 and Visual Studio Express C++
> I manage to compile the whole GDAL-project. I manage to compile C#
> bindings with CSHARP_STATIC_LINKAGE = YES and CSHARP_STATIC_LINKAGE = NO
> but NOT with it commented out.
> The compile with CSHARP_STATIC_LINKAGE = NO do not seem to affect the
> result as would be needed. When I try to set up a SpatialReference with
> an EPSG-code I still get a 6.
> With CSHARP_STATIC_LINKAGE  commented out the compilation halts when
> creating gdal_wrap.dll:
> > LINK : gdal_wrap.dll not found or not built by the last incremental link; perfor
> > ming full link
> >    Creating library gdal_wrap.lib and object gdal_wrap.exp
> > gdal_wrap.obj : error LNK2019: unresolved external symbol _GDALIdentifyDriver at 8
> > referenced in function "void * __cdecl IdentifyDriver(char const *,char * *)" (?
> > IdentifyDriver@@YAPAXPBDPAPAD at Z)
> > gdal_wrap.dll : fatal error LNK1120: 1 unresolved externals
> > NMAKE : fatal error U1077: '"C:\Program\Microsoft Visual Studio 8\VC\BIN\link.EX
> > E"' : return code '0x460'
> > Stop.
> Why is it never as simple? Do I miss something?
> /Tomas
> Tamas Szekeres skrev:
> > Tomas,
> > You'll have to comment out the
> > in csharp.opt and recompile the C# interface. Using this setting the
> > csharp dll-s will link against the gdal14.dll so the
> > PushFinderLocation and ImportFromEPSG will operate on the same global
> > data. In the future I consider to use this setting as the default
> > option.
> > BTW: I would propose to use the latest development version of the C#
> > related stuff. There were some fundamental changes in the interface
> > that might cause some changes in the existing code. For more
> > information see:
> > http://trac.osgeo.org/gdal/wiki/GdalOgrCsharpVersions
> > You might also use the binaries of the latest FWTools
> > http://test.gdal.org/fwtools/FWTools130.exe
> > and replace the *_wrap.dll-s and *_csharp.dll-s inside with the
> > compiled version.
> > Best regards,
> > Tamas
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
