[Gdal-dev] Re: Problem using EPSG in C#
Tomas R monshi at home.se
Sun May 13 03:55:44 EDT 2007
Sounds like good way too solve this.
Totally OT:
Not a big problem, not my primary e-mail I have used here but still,
seems like it has already found by some SPAM-idiots. The number of
e-mails with the correct address has raised a bit. To bad that was what
I knew would happen.
Yours
Tomas
Tamas Szekeres skrev:
> I've issued a ticket for this problem since the memory reference error
> is not the convenient way to indicate that the proj.dll is not
> loadable. In fact as I've recognized the exceptions are not propagated
> to C# for the osr classes. Tomorrow I'll fix this problem so that an
> exception will be raised with a more descriptive message ("Failed to
> create coordinate transformation" in this case)
> Best regards,
> Tamas
> 2007/5/12, Tomas R <monshi at home.se>:
>> Ahh, it works!
>> Can it be as simple fact as that the proj.dll in FWTools is named
>> proj_fw.dll and the binding in the gdal dll is towards proj.dll. I've
>> read about that problem in other posts...
>> Yes, I guess it is so...
>> And yes - to the other branch of this thread - only viable solution in
>> distribution of my application is to supply the necessary dlls together
>> with the application.
>> Perhaps a small guideline in the wiki about the dlls required is in
>> place? And links to where to find them, or compile them?
>> Thank you big time!
>> If you are into tracking your running or biking exercises with a GPS
>> take a look at SportTracks. In a short time v 2.0 will be released, I
>> hope, and soon thereafter my plugin will be released, I also hope.
>> /Tomas
>> > Tomas,
>> > I've eventually created a sample Windows application which executes
>> > the expected code when the button is clicked and the results are
>> > written into a textbox. I've attached the Visual Studio 2005 project
>> > to this mail including the necessary dll-s. You might alter
>> > SetConfigOption PushFinderLocation according to the place of your
>> > FWTools installation.
>> > In my experience when the proj.dll is removed from the application
>> > directory that memory corruption error may arise in that case when the
>> > %PATH% environment variable does not contain a proper location for the
>> > proj.dll in the system.
>> > Best regards,
>> > Tamas
>> >> Oh, did I post that version when I tried to go from WGS84 to
>> WGS84. Have
>> >> tried it before and then it changed nothing but still a test if
>> the call
>> >> works.
>> >> Tried your code and, no.. I have no idea why it won't work. But my
>> guess
>> >> is something work with compilation of gdal... Perhaps. (some path
>> that
>> >> perhaps needs to be set before compilation?)
>> >> Worth mentioning  is perhaps that GDALinfo, the included example,
>> work.
>> >> The include OSRTransform example give the same error as my own code.
>> >> Would have been a bit surprised if not.
>> >> It works to allocate the SpatialReferences and the
>> CoordinateTransform,
>> >> it is the call to transform the two points that fails.
>> >> Call stack:
>> >> >      [External Code]
>> ogr_csharp.dll!OSGeo.OGR.CoordinateTransformation.TransformPoint(double[]
>> >> > argout = {Dimensions:[3]}, double x = 1620000.0, double y =
>> 6597000.0,
>> >> > double z = 0.0) Line 57 + 0x2c bytes    C#
>> >> >      GdalTest1.exe!GdalTest.Form1.button5_Click(object sender =
>> {Text
>> >> > = "button5"}, System.EventArgs e = {X = 54 Y = 11 Button =
>> Left}) Line
>> >> > 101 + 0x2b bytes    C#
>> >> >      [External Code]
>> >> >      GdalTest1.exe!GdalTest.Program.Main() Line 17 + 0x1a
>> bytes    C#
>> >> >      [External Code]
>> >> As you can see it is runs from a Window Application but that
>> should not
>> >> have anything to do with.
>> >> The whole exception. A short translation of the message is, as
>> previous
>> >> said, " A try to read to read or write to protected memory. This
>> >> indicates often that another memory is damaged."
>> >> > System.AccessViolationException was unhandled
>> >> >   Message="Det gjordes ett försök att läsa eller skriva till
>> skyddat
>> >> > minne. Detta indikerar ofta att annat minne är skadat."
>> >> >   Source="ogr_csharp"
>> >> >   StackTrace:
>> >> >        vid
>> OSGeo.OGR.OsrPINVOKE.CoordinateTransformation_TransformPoint__SWIG_1(HandleRef
>> >> > jarg1, Double[] jarg2, Double jarg3, Double jarg4, Double jarg5)
>> >> >        vid
>> OSGeo.OGR.CoordinateTransformation.TransformPoint(Double[]
>> >> > argout, Double x, Double y, Double z) i c:\Documents and
>> Settings\Tomas\Skrivbord\GDalDoc\trunk\gdal\swig\csharp\ogr\CoordinateTransformation.cs:rad
>> >> > 57
>> >> >        vid GdalTest.Form1.button5_Click(Object sender, EventArgs
>> e) i
>> >> > d:\Documents and Settings\Tomas\Mina dokument\Visual Studio
>> >> > 2005\Projects\GdalTest1\GdalTest1\code\Form1.cs:rad 101
>> >> I downloaded the latest trunk and compiled with no error. Set
>> references
>> >> to the four CSharp-dlls and included gdal14.dll and the wrapper
>> dlls in
>> >> the project, all files after compilation in same folder. But when
>> I run
>> >> the code, same error.
>> >> And as said before: Environment to compile in is Visual Studio
>> Express
>> >> C++, 2005 environment for developing is Visual Studio Express C#
>> 2005.
>> >> Nothing strange.. Version 1.4.1 I have managed to compile and
>> run... But
>> >> of course not EPSG-codes in v 1.4.1
>> >> > Tomas,
>> >> > I couldn't find out what is the actual value of your WGS
>> variable in
>> >> > SpatialReference wgs84 = new SpatialReference(WGS);
>> >> > In addition CoordinateTransformation(wgs84, wgs84); doesn't seem
>> to do
>> >> > anything with the coordinate values.
>> >> > Here is my equivalent code that worked:
>> >> > int rtX = 1620000;
>> >> >                 int rtY = 6597000;
>> >> >                 Gdal.SetConfigOption("GDAL_DATA",@"C:\Program
>> >> > Files\FWTools1.3.0\data");
>> >> >                 Gdal.PushFinderLocation(@"C:\Program
>> >> >                 SpatialReference source = new SpatialReference("");
>> >> >                 int res = source.ImportFromEPSG(3021);
>> >> >                 string srcTest, dstTest;
>> >> >                 source.ExportToWkt(out srcTest);
>> >> >                 Console.WriteLine(srcTest);
>> >> >                 SpatialReference wgs84 = new SpatialReference("");
>> >> >                 wgs84.SetWellKnownGeogCS("WGS84");
>> >> >                 wgs84.ExportToWkt(out dstTest);
>> >> >                 Console.WriteLine(dstTest);
>> >> >                 CoordinateTransformation toWGS = new
>> >> > CoordinateTransformation(source, wgs84);
>> >> >                 double[] data = new double[3];
>> >> >                 toWGS.TransformPoint(data, rtX, rtY, 0);
>> >> >                 Console.WriteLine(data[0].ToString() + " " +
>> >> > data[1].ToString());
>> >> > However your memory corruption issue is somewhat frustrating, do
>> you
>> >> > have a call stack for this error?
>> >> > Best regards,
>> >> > Tamas
>> >> > 2007/5/11, Tomas R <monshi at home.se>:
>> >> >> I have received two answers in my mailbox but don't see them
>> here. I
>> >> >> reply to one of them:
>> >> >> The code I use to produce the error is:
>> >> >> >                 int rtX = 1620000;
>> >> >> >                 int rtY = 6597000;
>> >> >> > @"C:\Program\FWTools1.3.0\data");
>> >> >> Gdal.PushFinderLocation(@"C:\Program\FWTools1.3.0\data");
>> >> >> >                 put(srcTest);
>> >> >> >                 put(dstTest);
>> >> >> >                 put(data[0].ToString() + " " +
>> >> >> Where Put is just a call to a routine which displays the text on
>> >> screen.
>> >> >> Without gdal14.dll or all the wrapper dlls included in the project
>> >> the
>> >> >> code halts at first call to Gdal. With the wrappers and the
>> gdal dll
>> >> >> included in the project the SpatialRefernces are correctly
>> >> initialized
>> >> >> (wgs from a WKT-string, just for testing, source from ESPG  (have
>> >> tested
>> >> >> other than RT90)) but instead it halts at call to TransformPoint.
>> >> The
>> >> >> exceptions InnerException is null, error in OGR/OSR_sharp.dll.
>> I have
>> >> >> tested with both reference to OGR and OSR.
>> >> >> I have also tried copying all dlls from FWTool to the project but
>> >> with
>> >> >> no difference.
>> >> >> Thank you for your help! The time you take to clear this up is
>> highly
>> >> >> appreciated!
>> >> >> Yours
>> >> >> Tomas
>> >> >> This was in answer to
>> >> >> > Could you post your example that produces this behaviour? I
>> haven't
>> >> >> > found this issue when using a similar test you have mentioned.
>> >> >> > Tamas
>> >> >> Tomas R skrev:
>> >> >> > Again I was a bit to quick when reporting success.
>> >> >> > Yes, now I am able to create a SpatialReference from an EPSG
>> >> code and
>> >> >> > from Proj4 (not tested WKT)
>> >> >> > And I am able to create a CoordinaTransform object from those
>> >> >> > spatialreferences.
>> >> >> > But I'm not able to perform an actual coordinate
>> transformation, an
>> >> >> > exception is thrown (trying to read or write to  protected (in
>> >> >> > ogr_sharp.dll).
>> >> >> > So, again I ask:
>> >> >> > Have I missed some step or is it still something in GDAL that
>> >> doesn't
>> >> >> > work?
>> >> >> > /Tomas
>> >> >> > Tomas R skrev:
>> >> >> >> Ok Tamas, it kind of works...
>> >> >> >> I followed the steps you have described for me and those I
>> >> found on
>> >> >> >> the Wiki:
>> >> >> >> 1: Downloaded latest trunk
>> >> >> >> 2: Compiled  GDAL (how many of the steps must I do? All? Or
>> >> just the
>> >> >> >> first, I guess just the first)
>> >> >> >> 3: Created the C# interface and compiled it.
>> >> >> >> 4: Copied the resulting *_wrap.dlls to Fwtool1.3.0\bin folder
>> >> >> >> 5: Added the new CSharp-dlls to my C# project.
>> >> >> >> 6: Checked that the system path contains FWTools1.3.0\bin
>> folder
>> >> >> >> If I try running my project after those steps I get an
>> >> exception when
>> >> >> >> trying to call GDAL, whatever *_wrap.dll that is called is not
>> >> >> >> found/not possible to load.
>> >> >> >> When I add the wrap-dlls to the "root" of my C#-project, no
>> >> apparent
>> >> >> >> change.
>> >> >> >> When I copy the GDAL-dll to my projects root and include it
>> in the
>> >> >> >> build, together with the wrap-dlls, it works!
>> >> >> >> But is this how it now is supposed to be? I guess I with this
>> >> setup
>> >> >> >> can use GDALs basic function but all the functions which
>> rely on
>> >> >> >> other libs (which I have not tested/any knowledge of yet)
>> are not
>> >> >> >> available? For example reading and writing of GeoTiff images?
>> >> (That
>> >> >> >> is possible via the C#-bindings?)
>> >> >> >> For now I think I'm content with coordinate translation but I
>> >> think I
>> >> >> >> want to try how efficient GDAL is to use when importing maps of
>> >> >> >> different formats. It would be nice to be able to rip directly
>> >> from
>> >> >> >> GeoTiff (or RIK) with GDAL.
>> >> >> >> Perhaps a bit OT but:
>> >> >> >> In basic it boils down to that I have now not a clear idea
>> how to
>> >> >> >> distribute the plugin I am building. Demand that FWTools are
>> >> >> >> installed or include the nessecary dlls? O well, there is time
>> >> left
>> >> >> >> to think about that.
>> >> >> >> /Tomas
>> >> _______________________________________________
>> >> Gdal-dev mailing list
>> >> Gdal-dev at lists.maptools.org
>> >> http://lists.maptools.org/mailman/listinfo/gdal-dev
