[Gdal-dev] r.out.gdal vs gdal_translate vs gdalwarp
Maciej Sieczka tutey at o2.pl
Sun May 13 09:45:55 EDT 2007
Hi!
I'm really puzzled. Please can somebody look into this?
I tried to simplify the case a bit. Let's leave out r.out.gdal for a
moment and stick to GDAL commands only. A sample vegcover3.tif is
attached, but you should be able to reproduce the issue with any tiff
out there.
The sample size is 28628 bytes.
Try the following on the sample:
$ gdal_translate vegcover3.tif vegcover3_gt.tif
vegcover3_gt.tif size is 28628 bytes. Identical to input. OK.
$ gdalwarp vegcover3.tif vegcover3_gw.tif
vegcover3_gw.tif size is 36336 bytes. That's 27% bigger than the input!
But why? I can't see a reason there should be any difference. gdalwarp
is supposed to do a raw copy of the input if no switches present; or
isn't it? Maybe I'm just missing something.
Maciek
Type: application/x-bzip
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20070513/6f0c23f9/vegcover3.tif.bin
